D
Deleted User
Guest
I just got the mytouch 4g after talking with you all on the forum and getting great info on the device it is a no brainer for my needs. All was fine when I got it yesterday and was in a major city all day, THEN I got home and the problems have come.
I double checked my home location on their coverage map and it's green to dark green, only white is in a town down the street but it's far enough away on the map to where it shouldn't be a problem.
I can only get Edge service at home, and when trying to select the network setting to force 3g/4g it jumps back to GSM only on it's own. Trying a factory reset right now, but i'm on the verge of taking this back if i can't get good service at home.. any suggestions?? :-/
. Depending on your internet usage thst might not even be feasible since we have s 5gig data cap before our speeds are throttled. Also, you might check the coverage map again. The green shows voice coverage, but there is a separate map to show data coverage in shades of purple.
