MyWay Tracker v0.2 RELEASED
  • Thread starter Thread starter koulik
  • Start date Start date
K
koulik
Guest
Simple widget-based application that allows:
- Save your actual position through one click on widget button
- Periodic tracking (Start/Stop through widget)
- Managing your Ways and saved positions
- Show your Ways in Google Maps
- GPS, network or both locating methods
Changelog for version 0.2:
- New Widget look (remove old and add new to reload layout)
- New icons
- Launcher icon
- Improved network locating (now uses GPS and after network)
- Pref. option to store position only when it differ from previous one
- New menu options in map - go to start/go to end of the Way:)
I'm sure this is a great product but I guess i'm doing something wrong as I start a track and check on on the map (map view) and it always pulls up a map of Tulsa, OK. I'm in Cincinnati!
Google Maps pulls up my correct location instantaneously, so I'm not sure why My Way shows me somewhere else. I have "Use network for localization" turned on - thought it would help but it didn't seem to make a difference.
Thanks,
Kevin
