karandpr
Android Expert
Disclaimer : Your warranty ceases to exist from this step on wards .SO are your power shields and all those charms protecting you .I am not responsible for bricked phones,burnt dinners,nuclear wars,unemployment ,insanity,baldness, divorces with alimony,pokemon and any other thing that happens to you
This is how you install Arkas or Stock Samsung Firmware
For better results clear data/cache from recovery mode
Recovery Mode = T(keyboard T as in Q-W-E-R-T)+power
Done
Operation System :Windows
Program required : Odin_Multi_Downloader v4.34
From samfirmware.com get the callisto.ops script from the Login - www.SamFirmware.com
You will need to register to access the site
Download Stock ROM from samfirmware .
Download Links for Arkas are on my blog
Some basic knowledge or warning
Brazil and Argentina users need the
amss_phone and CSC from Brazilian firmware
You can get it from Topic: the challenge - www.SamFirmware.com
AND /OR
[Q][HELP] Lost GPS after Flashing Samsung Galaxy 551 (i5510L) - xda-developers
French and AZERTY users
They will require the Belgium CSC for AZERTY k[/COLOR] yboard
Austrian,German and QWERTZ users
Austrian settings are required for QWERTZ settings
*#272* IMEI # is the code used to change country settings
The Flash
1.)Drink 2 glasses of water,wash your face ,Look in the mirror and say "I can do it 50 times "
2.)Cross check the list of items
Items required in your hand
Items on computer
3.)Open Odin and in Select OPS option ,click OPS and load callisto.ops
4.)Now the four options of Odin are highlighted
5.) Click on PDA and load PDA.tar.md5
6.)Connect the phone to computer and switch off phone.
7.)Press Q(keyboard Q of Q-W-E-R-T-Y)+Power button simultaneously.
Your phone screen should look like below
Odin should detect you phone
The Odin should look like below
8.) If both phone and odin are look like above then click Start
9.)Wait some time,twiddle thumbs,comb hair ,check your teeth ,work on the kooky maniac laugh,
10.)After 5 minutes or so phone will reboot and you will have spanking new ROM installed
The Video tutorial of from Orkut Brazil for One Package Flash option
http://www.youtube.com/watch?v=a2dq_BNN1aM&feature=player_embedded
Done
AND /OR
The Flash
- Samsung Galaxy 551 aka I5510 aka Callisto
- Working Flawless USB cable.
- A computer with USB port and power supply for span of 45 minutes
Items on computer
[*]Odin_Multi_downloader v4.34
[*]Windows Running
[*]Samsung USB drivers or KIES preinstalled
[*]PC should recognize the phone
[*]KIES should NOT be running in background
[*]PDA.tar.md5 file of ARKAS
[*]Callisto.ops
