bhaskarbhaskarrana
Hi guys
i am writing this after exhausting all the options , which i can think of.
i am having samsung galaxy note 2 , GT N7100 , INDIA version.
its almost 2 year old , i have take very good care of the phone & it was working all fine.
but last week , i dint have the charger so i asked my frind & he gave a USB cable with hub attached.
the phone charged perfectly & was working fine while i went to sleep.
after i woke up there was only the boot logo of samsung.
I HAVE NEVER ROOTED OR ANYTHING.
ONLY DID UPDATEING THAT TOO SAMSUNG OFFICIAL OTA , NOT BY ANY OTHER MEANS.
THAT TOO FAR LONG BACK , NOT DONE ANY UPDATE RECENTLY.
i tried restarting , but dint worked.
i went to recovery mode , but i all i see is
everything in red ----
____________________________________________________________________
E:failed to mount /efs (no such file or directory )
# MANUAL MODE #
-- Appling Multi-CSC...
E:failed to mount /system (no such file or directory )
Can't mount '/system (no such file or directory )
E:failed to mount /cache (no such file or directory )
Can't mount '/cache (no such file or directory )
Can't mount '/cache/Recovery/last_recovery
E:failed to mount /data (no such file or directory )
Can't mount '/data/log/recovery_log.txt
.......(AND SO FORTH)
_____________________________________________________________________
then i get
Android system recovery <e3>
KOT49H.N7100XXUFNL1
reboot system now
apply update from ADB
apply update from external storage
wipe data/factory reset
wipe cache partition
apply update from cache
i had tried wiping cache & factory reset but nothing much happens.
i downloaded this file from samsung updated.com .INU version.
N7100XXUFNL1_N7100ODDFNI1_N7100DDUFND1_HOME.tar
then i tried with external storage , but still doesnt work.
then i tried through KIES software (both kies & kies 3.0)
phone was not able to connect
so i tried through FIRMWARE UPGRADE & INITIALIZATION
entered my model number & S/N.
after complete downloading , it says it cant locate the phone.
then i downloaded ODIN.
phone in handset mode says -
ODIN MODE
PRODUCT NAME: GTN7100
CURRENT BINARY: SAMSUNG OFFICIAL
SYSTEM STATUS: OFFICIAL
KNOX WARRATNY VOID: 0
RP SWREV: A2
verion 1.85 , 3.09 . 3,10
went into downlaod mode by - vol down+power+home
copied the same file - N7100XXUFNL1_N7100ODDFNI1_N7100DDUFND1_HOME.tar in PDA.
but it failed eveytime.
tried on 7 laptops , 14 cables .also tried changing the directory of tar file in laptop.
<ID:0/004> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> N7100XXUFNL1_N7100ODDFNI1_N7100DDUFND1_HOME.tar.md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/004> Odin v.3 engine (ID:4)..
<ID:0/004> File analysis..
<ID:0/004> SetupConnection..
<ID:0/004> Initialzation..
<ID:0/004> Get PIT for mapping..
<ID:0/004> Firmware update start..
<ID:0/004> sboot.bin
<ID:0/004> NAND Write Start!!
<ID:0/004>
<ID:0/004> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
then i thoguht trying to root it.
may be that will work.
downloaded files -
Note2-CWM-6.0.4.3-GT-N7100
openrecovery-twrp-2.8.4.0-t03g.img
twrp-2.6.1.0-testing-t03g.img
twrp-2.7.1.0-t03gduoszn.img
twrp-2.8.0.0-t03g.img
twrp-2.8.5.0-t03g.img
cm-Resurrection_Remix_LP_v5.2.4-20141221-n7100
everytime it went for some little time on green color in odin for recovery file.
but then it failed.
<ID:0/004> recovery.img
<ID:0/004>
<ID:0/004> Added!!
<ID:0/004> SingleDownload.
<ID:0/004> FAIL!
<ID:0/004>
i also tried CASUAL software -
BackAtchaVerizon-CASUAL-Revision465b
it says - in software window ,
[Heimdall Error Report] Detected:
'LIBUSB_ERROR_NOT_SUPPORTED'; Attempting to continue
[/Heimdall Error Report]
Heimdall v1.4 RC2
Copyright (c) 2010-2012, Benjamin Dobell, Glass Echidna
http://www.glassechidna.com.au/
This software is provided free of charge. Copying and redistribution is
encouraged.
If you appreciate this software and you would like to support future
development please consider donating:
http://www.glassechidna.com.au/donate/
Initialising connection...
Detecting device...
ERROR: Failed to access device. libusb error: -12
Drivers are Required Launching CADI.
CASUAL Automated Driver Installer by jrloper.
Installing Drivers now
it says - in mml window , from last part
cadi :debug [installer process] more recent driver was found <force option required>
cadi:info [wdi_install_driver] Success
driver Install Failed....
Target device found :"dg_ssudbus" found at :<048:6860>
preparing Driver...
cadi:info [wdi_prepare_driver] success
No target devices installed...
quitting....
then it start for CADI.exe
when i press yes , igoes on & on like this.
i already installed all the driver through zadig .
but still doent work.
# MANUAL MODE #
then i get
KOT49H.N7100XXUFNL1
reboot system now
ODIN MODE
RP SWREV: A2
<ID:0/004> Added!!
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/004>
downloaded files -
but then it failed.
<ID:0/004>
<ID:0/004> Added!!
<ID:0/004> FAIL!
<ID:0/004>
Heimdall v1.4 RC2
encouraged.
Detecting device...
preparing Driver...
quitting....
