Help N950F Boots only into recovery and not the OS
NoteEight
I have tried flashing the latest firmware with the correct carrier using Odin but this has not worked.
Error message on the recovery screen
#fail to open recovery_cause (No such file or directory)#
#Reboot Recovery Cause is [UNKNOWN]
#Support SINGLE-SKU
File-Based OTASupported API: 3
E:unknown volume for path [/odm]
E:unknown volume for path [/vendor]
dm-verity verification failed
E:[libfs_mgr]is_dt_compatible(): firmware info was not valid : '/proc/device-tree/firmware/android/compatible : No such file or directory
ok is there a way for you to post a screenshot of the exact output from odin?
This is the log in Odin:
<ID:0/006> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> Leave CS..
<OSM> Please wait..
<OSM> Leave CS..
<ID:0/006> Odin engine v(ID:3.1401)..
<ID:0/006> File analysis..
<ID:0/006> Total Binary size: 6151 M
<ID:0/006> SetupConnection..
<ID:0/006> Initialzation..
<ID:0/006> Set PIT file..
<ID:0/006> DO NOT TURN OFF TARGET!!
<ID:0/006> Get PIT for mapping..
<ID:0/006> Firmware update start..
<ID:0/006> NAND Write Start!!
<ID:0/006> SingleDownload.
<ID:0/006> sboot.bin
<ID:0/006> param.bin
<ID:0/006> up_param.bin
<ID:0/006> cm.bin
<ID:0/006> boot.img
<ID:0/006> recovery.img
<ID:0/006> system.img
<ID:0/006> userdata.img
<ID:0/006> dqmdbg.img
<ID:0/006> modem.bin
<ID:0/006> modem_debug.bin
<ID:0/006> cache.img
<ID:0/006> omr.img
<ID:0/006> RQT_CLOSE !!
<ID:0/006> RES OK !!
<ID:0/006> Removed!!
<ID:0/006> Remain Port .... 0
<OSM> All threads completed. (succeed 1 / failed 0)
well it seems to have worked. i did not see any errors on this run.
care to explain how your phone is? what happened to it when this all happened? the more info we have, the better we can help.
After the Odin flash, the phone reboots into the Installing system update screen. It gets up to 32% then says erasing. The phone reboots again where it says installing a system update, then it says no command with a yellow caution sign and then it goes into the recovery screen.
what happened to the phone when all this happened? was this random? after an update? were you trying to root the phone?
The phone randomly started restarting itself and when I would shut it down, it would reboot. I tried to factory reset the phone but then it wouldn't work. So I booted into recovery and cleared the cache and factory reset there and then it wouldn't boot to the OS anymore, just boots into the recovery screen.
sounds like your system partitions are corrupted and if flashing a firmware update does not work, i'm afraid your phone is toast. this phone came out in 2017. i think its time to upgrade your phone.
