I have an Idroidnation (168G) box that I used with kodi (formerly known as XBMC) for Google TV. It comes with a 2.4 gb internal storage and 2.6 gb NAND flash. I also have a 128gb external sd card. I was unable to install certain things shortly after I got the box, getting a message that I do not have enough space.
I tried to move all the apps I could into the external sd card, but whenever I did that the apps moved into the NAND flash memory, not the external 128 gb sd card.
HOW DO I FORCE ANDROID TO DO WHAT I WANT, which is to move user-installed apps into the external sd card? Is there an app for that? The application manager and several apps I tried all treat the internal NAND flash memory as the "sd" card destination, and completely ignore my external sd drive!
Thanks--
Thanks--
. So what can you do? The answer is that you would need to root the device to be able to do anything - to overcome the shoddy implementation the manufacturer has provided you need administrator access. If you can root it (the techniques depend on the device, and I have no experience of this model) then you might be able to use an app like Link2SD to allow you to use the physical SD card for apps. You will not be able to accept system updates if you root the device (well you can, but it's at your own risk: they will certainly break root, and may introduce other problems, so I'd not recommend it). But those are your options: investigate the possibility of rooting it, or live with the limitations the manufacturer has built in. Sorry.
