Apps Navigation Drawer not changing fragment.
RivaCom
I'm trying to get the navigation drawer down, i've followed a few tutorials around the internet however they all end up not working. Now I know it's something simple but I can't figure it out. Menu opens, main fragment loads, but if I click a new fragment, nothing works. ideas?
activity_main.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<android.support.v4.widget.DrawerLayout xmlns:android="http://schemas.android.com/apk/res/android"
    xmlns:app="http://schemas.android.com/apk/res-auto"
    xmlns:tools="http://schemas.android.com/tools"
    xmlns:ads="http://schemas.android.com/apk/res-auto"
    android:id="@+id/drawer_layout"
    android:layout_height="match_parent"
    android:fitsSystemWindows="true"
    tools:openDrawer="start">
    <include
        layout="@layout/app_bar_main"
        android:layout_height="match_parent" />
    <android.support.design.widget.NavigationView
        android:id="@+id/nav_view"
        android:layout_width="wrap_content"
        android:layout_gravity="start"
        app:headerLayout="@layout/nav_header_main"
        app:menu="@menu/activity_main_drawer" />
</android.support.v4.widget.DrawerLayout>
MainFragment java
Code:
    package com.autotools.autotools;
    import android.app.Activity;
    import android.os.Bundle;
    import android.support.v4.app.Fragment;
    import android.view.LayoutInflater;
    import android.view.View;
    import android.view.ViewGroup;
    public class MainFragment extends Fragment {
    public MainFragment() {
    @Override
    public View onCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState) {
        View rootView = inflater.inflate(R.layout.fragment_main, container, false);
        // Inflate the layout for this fragment
        return rootView;
Second Fragment
Code:
    public class autoLoanFragment extends Fragment {
    public autoLoanFragment(){
    @Override
       return inflater.inflate(R.layout.fragment_autoloan,container,false);
MainActivity java
Code:
    import android.support.v4.app.FragmentManager;
    import android.support.design.widget.FloatingActionButton;
    import android.support.design.widget.Snackbar;
    import android.support.design.widget.NavigationView;
    import android.support.v4.view.GravityCompat;
    import android.support.v4.widget.DrawerLayout;
    import android.support.v7.app.ActionBarDrawerToggle;
    import android.support.v7.app.AppCompatActivity;
    import android.support.v7.widget.Toolbar;
    import android.view.Menu;
    import android.view.MenuItem;
    import com.google.android.gms.ads.AdRequest;
    import com.google.android.gms.ads.AdView;
    public class MainActivity extends AppCompatActivity
        implements NavigationView.OnNavigationItemSelectedListener {
    @Override
        setContentView(R.layout.activity_main);
        Toolbar toolbar = (Toolbar) findViewById(R.id.toolbar);
        setSupportActionBar(toolbar);
        DrawerLayout drawer = (DrawerLayout) findViewById(R.id.drawer_layout);
        ActionBarDrawerToggle toggle = new ActionBarDrawerToggle(
                this, drawer, toolbar, R.string.navigation_drawer_open, R.string.navigation_drawer_close);
        drawer.setDrawerListener(toggle);
        toggle.syncState();
        NavigationView navigationView = (NavigationView) findViewById(R.id.nav_view);
        navigationView.setNavigationItemSelectedListener(this);
        MainFragment fragment =  new MainFragment();
        android.support.v4.app.FragmentTransaction fragmentTransaction = getSupportFragmentManager().beginTransaction();
        fragmentTransaction.replace(R.id.content_frame, fragment);
        fragmentTransaction.commit();
    @Override
    public void onBackPressed() {
        if (drawer.isDrawerOpen(GravityCompat.START)) {
            drawer.closeDrawer(GravityCompat.START);
        } else {
            super.onBackPressed();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.main, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatically handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        //noinspection SimplifiableIfStatement
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
    @SuppressWarnings("StatementWithEmptyBody")
    @Override
    public boolean onNavigationItemSelected(MenuItem item) {
        // Handle navigation view item clicks here.
        if (id == R.id.nav_home) {
        } else if (id == R.id.nav_autoLoan) {
            autoLoanFragment fragment =  new autoLoanFragment();
        } else if (id == R.id.nav_gas) {
        } else if (id == R.id.nav_settings) {
        } else if (id == R.id.nav_share) {
        } else if (id == R.id.nav_send) {
        return true;
Fragment_main xml
Code:
    <FrameLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_height="match_parent">
    <TextView
        android:layout_height="wrap_content"
        android:textAppearance="?android:attr/textAppearanceLarge"
        android:text="Large Text"
        android:id="@+id/textView2"
        android:layout_gravity="center_horizontal|top" />
    </FrameLayout>
activity_main_drawer xml
Code:
    <menu xmlns:android="http://schemas.android.com/apk/res/android">
    <group android:checkableBehavior="single">
        <item
            android:id="@+id/nav_home"
            android:icon="@drawable/ic_info_black_48dp"
            android:title="Home" />
        <item
            android:id="@+id/nav_autoLoan"
            android:icon="@drawable/ic_attach_money_black_48dp"
            android:title="Auto Loan Calculator" />
        <item
            android:id="@+id/nav_gas"
            android:icon="@drawable/ic_local_gas_station_black_48dp"
            android:title="Slideshow" />
        <item
            android:id="@+id/nav_settings"
            android:icon="@drawable/ic_settings_black_48dp"
            android:title="Settings" />
    </group>
    <item android:title="Communicate">
        <menu>
            <item
                android:id="@+id/nav_share"
                android:icon="@drawable/ic_menu_share"
                android:title="Share" />
            <item
                android:id="@+id/nav_send"
                android:icon="@drawable/ic_menu_send"
                android:title="Send" />
        </menu>
    </item>
    </menu>
You're missing an element in activity_main.xml
This piece of code places the fragment
Code:
but it doesn't get added because R.id.content_frame doesn't exist. Add this element to activity_main.xml
Code:
<FrameLayout
    android:orientation="vertical"
    android:id="@+id/content_frame">
</FrameLayout>
Sorry, my content_main has content_frame , i tried changing it to activity main and still no success.
Code:
<RelativeLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:paddingBottom="@dimen/activity_vertical_margin"
    android:paddingLeft="@dimen/activity_horizontal_margin"
    android:paddingRight="@dimen/activity_horizontal_margin"
    android:paddingTop="@dimen/activity_vertical_margin"
    app:layout_behavior="@string/appbar_scrolling_view_behavior"
    tools:context="com.autotools.autotools.MainActivity"
    tools:showIn="@layout/app_bar_main">
   <FrameLayout
   </FrameLayout>
</RelativeLayout>
Set a breakpoint at the line where the fragment is replaced. Then step through the code. What happens?
So it looks like it's not getting to any of that function, i put break points in multiple spots with no luck. I guess why is it skipping it?
Probably caused by part of your project you did not provide above. A reasonable extrapolation based on what you provided appears to work as intended - MainFragment is loaded initially, clicking on "Auto Loan Calculator" loads
autoLoanFragment, and clicking on "Home" loads MainFragment; naturally the other menu items do nothing (not implemented). I've attached the sample project's source tree.
Tested on android version 6.0.1.
