Help Navigation Voice Synth Problem
Just today, my Droid 2 started having a problem with the voice synthesized for navigation - or perhaps two problems?
1. The normal female voice for giving directions is replaced by a slow male voice that does not give directions.
2. The voice I do hear is not giving directions at all, but is apparently reading information that sounds very much like an 'About' bubble for the navigation program, including version numbers, websites, XML versions, etc.
Any help would be much appreciated.
Thank you for the advice and I will try those voices. On the other hand I tracked down the culprit for my problem. Seems I had loaded an app called "e-Speak" since the last use of the navigation and when I un-installed it, the problem went away.
Hope this helps someone else along the way. Cheers.
