Help navigation
thequeenscheese
Android Expert
i was using google nav for the first time yesterday as i normally use the garmin but thoiught id give it a whirl on a long journey but it was too quiet i had the media volume up to full after pressing up volume then the volume cog tab is there an internal volume for google nav - i couldnt see one, im running official polish jb if that makes a diff?
its apitty because its making me stick to the garmin i wonder if its to do with the speaker more or less aiming for the heater vent altho i think the speaker in call is louder, i dont really want to use the radio as a speaker as i still would have it on obviously pretty low volume but still with the garmin can have both quite loud with no problem
I had a Garminfone before the S3, navigation on that was superior.
I actually keep the garmin in the car for navigation because the S3 couldnt keep up in Seattle/Tacoma when I was up there last week.. Hope someone resurrects that idea again.
You could try a different voice. Some voices are louder than others. I have the same issue with Maps. Although I can hear fine, I want it to be a little louder. I play my music from my phone as well and apparently, the music is just loud compared to the voice in Google Maps.
how do you change the nav voice i havnt noticed a setting for that?
when i say quiet i mean quiet sometimes i cant hear it over the engine nevermind the radio, and it is the app as the phones loud speaker is very good i find in other uses..
From your home screen, go into the settings. Then Language and input | Text-to-speech output. Look at your preferred engine. Mine is Google. Then go into those settings and Language. I chose English (United Kingdom). I find that the UK voice is a bit louder than the US voice.
already on the uk voice anyways, is there any real diff between the samsung and googlie voices or adv to using either of them
