NC CM7 Minecraft Pocket
macsblow
Hello,
I was trying to find out if there is a way to install Minecraft Pocket from Google Play (new store name). It says that my device is not compatible but I have seen other people have been able to install and play it. I tried rolling back the Google Play to its previous version but that doesn't work either. Any ideas?
Thanks!
If i were you i would go to Apk New and search for minecraft pocket edition and it should come up with all the versions so pick the one you want and install it
Hoped it helped
P.S it is the full version
