Nearly all of the Casio commando problems will be solved if you flash this rom (GzOne_World_Stock_v1.0)
https://drive.google.com/file/d/0B_691U8qGnlFLWFRdGxWU0xLZXc/view
The rom is flushable on both c811 and ca201l models.
The rom is base Korean model (ice cream 4.0.4).
The only problem is roaming that I have solved it already.
Solution:
Install xposed installer, and inside the software in download section after installing national roaming and putting sign in modules section, reboot system.
Everything is fine.
Enjoy it.
Solution:
Everything is fine.
Enjoy it.
