need a advice on control scheme
sdinesh86
Hello,
This is my first post on Android forums.
I bought a Android tablet and started playing some games on it, after some time i thought of making one myself for the device.
so i am making a game pretty similar on the lines of pool and in 3D,
the target is to point the object in a direction and shoot it right in pot.
so now i have worked on a control scheme which is most commonly used with tablets that is Joystick and D-Pad.
Description :
  • Left Joystick :
    Side to Side Movement : Rotate the object or set the Direction.​
    Slide Stick Up or Down : Set the power to shoot the object.​
  • Right Joystick :
    Side to Side Movement : Set the position of the object which is only in one axis
    Tap the stick : to shoot.
Now i just wanted to know if this is kinda Control scheme that a Handheld gamer would like to use and play with.
so need your comments on the control scheme.
Thanks.
