droidykate
I use a Samsung galaxy tab 4 for work, I'm doing a field beta test to see if they will work for our field workers (I work in environmental services for a construction company).
That being said, I often have reports in a .docx format that are sometimes up to 147 mb and the larger reports are the ones that prove to be most difficult to convert, even adobe will not touch that size of file with a ten foot pole.
Does anyone have a suggestion for a consistent pdf converter? I'm even open to using a combination of apps to try to get the ball rolling.
Thanks!
Thanks!
