Need a firmware for NEXBOX A95X-B7N
milo23
Hello,
i need a newer firmware for NEXBOX A95X-B7N i currently have android 6.0.1.
I bought this device used and there was an app installed to update other apps as I remember it well ustore.
I thought it was the manufacturer's application, but after restoring to factory settings, this application is no longer installed, nor can I find it on the Internet. Do you know where it can be downloaded from? Or which application to download for updating applications on a device without a google protect certificate, i.e. updates and installation of applications outside the play store, e.g. netflix?
thank you but this is probably only for the 2g/16g version and I have the 2g/8g version.
Is it original software from the manufacturer?
I saw a comment that someone had a problem with this software
Is there no knowledgeable people on this forum?
I will write below for others what I have determined, although my device works so I don't want to risk it without the support of an expert or confirmation of someone who has already done it that it is safe ...
I found probably the original Android 7 firmware for all versions provided by the manufacturer at:
I also found this on another forum:
Yes, that sounds correct for this device.
Good luck.
