soutrhernraider
Guys im tryin to update to 2.1 but the updater only goes as far as the prepare stage and then i get a message saying there was a problem so lets try again! This has happened 5 times! whats wrong??
Guys im tryin to update to 2.1 but the updater only goes as far as the prepare stage and then i get a message saying there was a problem so lets try again! This has happened 5 times! whats wrong??![]()
still nothing my friend!! thanks for your help anyway!!If you are using the PC Companion to update, then I would highly suggest downloading SEUS from the Sony website.
I was never able to upgrade to 2.1 using PC Companion and had to install SEUS to upgrade.
Sony Ericsson - Support - Softwaredownloads - Detailed - Updateservice - Xperia? X10
One more thing you can do is restart the phone if you haven't. Definitely try a different USB port. I was able to update to 2.1 on one port, then a week later, I needed to plug into another port for a small update after that.
Make sure you are logged into Windows with an Administrator account....or in Windows 7 right click on the SEUS app after you installed it and chose to Run As Administrator.
I am sure you'll get it.
even the rooting process didnt work! this is insane!What does it do? Does it quit while downloading the file from Sony or does it get past that and quit at the install somewhere?
For me the problem was downloading. But that was probably because my cell provider and Sony had just released 2.1 and there was a mad rush whee everyone was downloading it.
Does the phone go to Flash mode? Turn phone off....hold back button while plugging phone into USB port. And the Green light shows...but the phone appears off?
You might want to first remove any software installed on the phone and do a repair on the phone first using SEUS and see if it will let you do that.
All else fails I am sure you could just root it and install 2.1 the other way.
You could follow this guide and download any version you want - http://androidforums.com/x10-all-things-root/272949-flashtool-guide-how-n00bies.html
Hey my freind! Thanks for your help but nothing worked! The flash tool said "preparing files for flashing" then the green light went off and the phone restarted! UGH!!!If you can't update or do anything...you might want to try and reflash using that link:
You download the X10 flasher, download the x10a or x10i depending on what you have and flash the phone with 2.1 fresh. If it fails, exactly what step does it fail at?
Make sure you are using the Sony x10 USB cable that came with the phone.
Anyone else have any other suggestions?
Dude thanks for all of your help! Gave it a few more tries and nothing happens! After the green flash light comes on,the phone restarts and the program shuts down(SEUS,PC Companion,and the x10 Flash Tool)Use a different USB port on the computer.....Right click the x10Flash program and chose to Run As Administrator.
a. Unplug your USB cable from PC (unplug the USB cable on the PC, not the phone)
b. Power off your phone (wait a couple seconds after it is off)
c. Press back button and keep your finger on button (keep that back button held down)
d. Plug USB cable to PC (while still holding back, plug it into the PC)
e. Check if the green LED appear
Then follow the onscreen steps.
If it is possible, maybe try this in a different computer. Are you running something strange?
YouTube - ‪Upgrading a Sony Ericsson Xperia X10 from 1.6 to Android 2.1 (Eclair) on a Rogers X10a‬‏
Watch from 1:35 - 2:00 min....The guy in the video is doing it the old way with no graphical interface. But that is another way to do it.
Open the x10 Flash program, remove battery, plug in USB and hold back button....while holding back and it is plugged in, insert the battery.
