Help Need a Notification LED Light for Samsung Galaxy S2
Does anyone know how to get a Led Notification Light for the Samsung Galaxy S2, I mean a App that truly works on the Galaxy S2, Help!
Thanks!
There's no light on the front of the device.
Unfortunately apps can't alter the physical world................................................... yet ;)
There is NoLed which theoretically works fine, i tried it for a bit, and it did the work good, though im not sure but i think sometimes i had missed calls or messages and it didnt show it, or maybe i missed it in the settings and it shows for a bit and then disappears... but give it a go, tell me what you think
Bln is the only way as ironass mentioned above and its what I use.
There is an app you can download called noled which mimics this via small indicators on the screen itself but running it can be quite a battery drainer even when no indicators are displayed.
Even bln drains the battery at quite a rate if the key leds are on for any length of time.
