Need android help
whatwhat
Hey everyone, I'm making an application on Motodev that finds barcodes as they are scanned for the visually impaired. There are two databases I'm using, on the SD card and on the web. If I cant find the barcode I'm looking for on the SD card then I'll search it on the web. The problem is I dont know of any way to continue the search from the application to the web. Any ideas? Thanks
