Need app for EXTREMELY simple task
TK423
I need an app that does an extremely simple task and despite looking all over the place I can't find one that can do it.
I simply need my phone to vibrate for half a second once every ten seconds for ten minutes.
It's for tension release and meditation purposes.
I've found apps that ring bells and make obnoxious Tibetan Monk-esque noises but that actually makes it distracting and defeats the purpose.
Any help is extremely appreciate. Thank you very much.
Easy: I would get my fav vibrator app (...) and make a script with Tasker to set it off like I want.
Any advice or tutorials on how one would actually go about doing that?
Try the Tasker forum under Applications.
http://androidforums.com/tasker/
It would be something like:
Create a Tasker widget
Create a task
Start the vibrator app
Wait a half second
Stop the app
Wait nine and a half seconds
Repeat for ten minutes.
But you have to find a vibrator app that doesn't require tapping on a choice to start.
* Tasker has vibrate under alerts. This will be really easy but I can't get the widget to work.
I had Tasker turned off. The widget only works when Tasker is on.
