Help Need Assistance in getting HTC DHD up and running
The431001
Hi folks,
My phone details are as below -
ACE PVT SHIP S-ON RL
HBOOT-2.00.0027
MICROP-0438
RADIO-26.14.04.28_M
eMMC-boot
Sep 7 2011, 19:06:24
Phone Current Possible specs -
Android Version - 2.3.5
HTC sense version - 3.0
software number - 3.13.720.2
Kernel version - 2.6.35.10-g931a37e - (Not sure about this one)
baseband version - 12.65.60.29U_26.14.04.28_M
Build number - 3.13.720.2 CL208029 - (Not sure about this one)
Here is the situation -
My Non-Rooted HTC DHD somhow got stuck yesterday morning, after i woke up. No idea why it happened and everything. I tried pulling out battery and restarting, also tried recovery but not help - it was stuck on 'HTC - quitely brilliant' splash screen.
So I went ahead and tried to factory-reset it from Vol-Down + Power button. The process rather ended quickly than anticipated (I have done this earlier once so know that it cant be so fast). Post this, after every reboot now, the phone takes very long on splash screen, and eventually goes up to HTC wallpaper (the colorful one) but no controls are loaded and nothing happens (not even any error message). it cant be shut down unless i pull out the battery.
So after this has happened, i also tried to see what happens in HBOOT -> FastBoot -> BootLoader and it showed me this error -
SD Checking ...
Loading ... [PD98DIAG.ZIP]
No Image!
So assuming that perhaps I need the correct ROM file, I started looking up on forums and tried below 2 RUU EXE files (with HTC Stock ROMs)-
1. RUU_ACE_HTC_WWE_1.32.405.6_Radio_12.28b.60.140e_26 .03.02.26_M_release_155891_signed.exe
2. RUU_ACE_Sese30_s_htc_wwe_3.12.405.1_radio_12.65.60 .29_26.14.04.28_m_release_225512_signed.exe
Well after running the first RUU.exe, I got a little wiser (I guess!) and understood that the RADIO version for RUU should match with my phones RADIO. So i tried the second one, which made me further wiser and i understood that the ROM Version in RUU should also match my phones current version.
Now after all this knowledge, when I tried to found an RUU/ ROM with
3.13.720.2 and Radio v 26.14.04.28_M, I am not able to get any file which suits my need.
1. Can someone please help me to understand, which ROM can be used to restore my phone to working condition (and if my analysis so far is correct or not)?
2. What would be the correct way to restore my phone to working condition, if I am doing something wrong?
PS: As of now, I just want to get it up and running w/o Rooting, if possible...
Thanks for helping me out -
~The431001
Hello and welcome to the forums - thanks for joining!
Is your phone carrier branded or is it unbranded?
If it is unbranded, I have a copy of the latest RUU that you can run from your computer that will put your phone back to stock unbranded.
Let us know and we will try to help you out :)
Just following on for D-U-R-X post if it's branded what carrier are you using? If so this could make it a bit more trickier as branded RUU's are hard to come by. Don't assume what you download off the net is branded. Hopefully your unbranded and we should have you up and running again.
Hi,
Thanks for your reply. My phone is unbranded. I managed to get it working by buring latest RUU from service center - 40KM away...! Would it be possible for you to share it the one available with you, so that I dont have to drive that far again just to get it loaded. The guy also said that next time he burns it, he will charge me some fees for the same, as the warranty will be over by end of Apr...
Thanks for your response. Really appreciate your help.
