Root need big help for Galaxy S
ferretan
it was an accident when the phone was at download mode. I disconnected the wire then the machine has no longer operate. The screen always showed "a cellphoe + "!" sign + a computer" pic on the screen.
I tried to use 3 bottom to reboot or whatever i did. the machine didn't responds at all.
Anyone has the same? Please help me how to fix.
Many thanks
This normally works if something is completely crashed:
Unplug the battery for a while, then put it back and restart. This works on my Nokias. I'm new to Android though, so it might not work.
Sounds like you have nothing to lose though!
I tried many times but.... anyway thanks. Anyone have faced the same problem?
Go to download mode and use odin to flash your rom.
I cant guaranty it will work but you'll have a chanche.
You're warranty probbabley wont have any effect vecause this is user fault and not phone.
I think flashing is your onley option
Volume Down + Power + Home should get you into download mode. Make sure the USB is not plugged in. If you can't get into download mode that way, you are going to need a jig. [HOWTO] [REF] Get Download Mode without 3-button combo using homemade JIG - xda-developers
Once you are in download mode, start up Odin. Now plug your phone in. Put the correct pit files, pda, phone, csc. Leave re-partition unchecked. Flash.
If that doesn't work, try once more with repartition checked.
