need data recovery help
Yea, internal memory, most likely not. SD card, yes, I would recommend GetDataBack. You would need the FAT version. The most important thing is to IMMEDIATELY take the sd card out of the phone, and dont use it until you are ready to recover. If you use it at all since the files were deleted, you are pretty much out of luck.
