amit_k20001@re
Member
I have downloaded need for speed shift(snapdragon) for my sony x8 (2.1).. But when i open it for installtion it says - unable to open ,delete some applications and try again , though its only 38 mb and i have 83 mb. Plz help
Its not installing it , when i opns it for install it says - out of space,free some space and try again though i hav 83 mb spacetry uninstalling and redownloading it
In sony x8 , i thnk you cant move application from phone memory to sd memory card , i think. or if you know the way please tell me.It may need more than the 83 mb free. Try uninstalling some apps. Generally if your phone tells you to free up some space you will need to. Also you can try moving apps to the SD to free up space as well.
