Help Need for speed shift on sgs3?
SUroot
Extreme Android User
Anyone got it working? I transferred from my 3.7 desire but not convinced it works at the resolution. Any owners confirm? I got huge blocks of missing menu screens
I just got an S3 and for some reason NFS is incompatible with device? Odd as it worked fine on my Nexus S.
Anyone one know why this is the case? Same with Dead space, some gameloft games and mass effect infiltration. All saying not compatible with my S3 on the play store!!
Was it a Titanium restore? I can confirm that the play store says it's incompatible with my S3. I wouldn't even be able to download it.
I expect there'll be a compatibility update for you at some point. Interestingly though, it says it's incompatible with all of my devices, which means my desire also. How did you get it to install in the first place?
EDIT: there are two versions of NFS Shift, one compatible with none of my devices, the other compatible with my Desire.
