Mt said reflashing the broken Out zip should fix it, but I guess not?
Alright guys, this should block the OTA from running. You may get a force close on boot, but just ignore it and you should be ok.
http://dl.dropbox.com/u/54501789/Spectrum/BlockOTASpectrum.zip
So i accidentally took ota(V6) today and am now stuck in recovery(CWM). I can navigate around there fine, but tried to factory reset, restoring nandroid, installing different ROM but everytime it reboots back into recovery. Any suggestions would be much appreciated.
I flashed back to v4, accepted ota, device rebooted itself to complete the software update and when rebooted it was stuck in recovery!
Thx for the tip hollywoods14 and your the man mtmichaelson...WORKED PERFECTLY!!!!
Neph's Boot Loop Fix zip i believe will also solve that issue.
