kev716
Hello All,
Well, I thought I wasn't a complete newbie having installed several custom ROMs on my LG Esteem & Amazon Kindle Fire, but my wife's Admire has me baffled. She doesn't want anything fancy but was frustrated by low memory messages and not being able to add the apps she wants. I saw the 2.3.6 Stock++ {(ROM)}.zip ROM and thought this would be ideal.
I used Odin to install CWM recovery, and then updated it to 6.0.3.2 so that I could flash different ROMs. I wiped everything first & it looked like the ROM flashed successfully, but it keeps crashing every few hours (SOD). I get the error message CMW-based recovery v6.0.3.2 E:can't open /cache/recovery/log & /recovery/las. I also can't install anything from the play market.
No problem I thought, I had made a back-up. Nope, that won't boot when I tried to restore it. I then tried other ROMs, OA2.3.20-FINAL-EXT4-900[FINAL]-Spz0.zip & ctmod 3.75.zip, but neither would boot after flashing. I also tried stock admire 2.3.4.zip without any luck.
My next thought was to try restoring CMW 5.0.2.7 again using Odin. I follow the same directions I had used before, but now when I connect the USB cable while holding down the camera button the phone doesn't turn on??
Does anybody have advice for me how to get a working phone again?
Thanks,
Kevin
Thanks,
Kevin
