Root Need help ASAP plz! - MIUI Rom help!!
blh2012
Just flashed to an MIUI rom and I love it, however I'm having service issues. The same problems many people have with this phone - texts not sending, no service, sudden signal drops, etc. Usually this happens to me sometimes when I flash a new rom and a profile update always takes care of it. However, "System Updates" has been removed from the settings in the MIUI Rom so I can't do a profile update and I also can't access the ##CLEAR# menu from an MIUI rom. So is there any way to do a profile update while running an MIUI rom? I don't wanna have to give this rom up but I'll have to if I can't get my service issues fixed. My signal appears to be abnormally low with this rom as well.
If it helps at all, I'm running a Sprint PRL, 60690.
Also, this ROM appears to be a tad slower than all other ROMS i've tried. I get a 2000 score on quadrant when I normally would get 3000-4000 with other roms. In No-Frills CPU control, the max is 1.18...are there any easy tweaks I can apply to overclock my processor? I'd like to be able to do 1.5 or higher.
