How did you install mint?it says I need a 2gb usb stick which i don't have!
If you really want help, I can help you, but you are going to have to post what I ask for.
At this point I see your options as this:
1.) Try it with a 1GB USB stick. Some of the smaller distros should fit and it might work.
2.) Get a 2GB USB Stick. You could borrow one from someone as you'll only need it for the install.
3.) Call Acer and hope they can walk you through the recovery process as long as your recovery partition is still intact.
4.) Take it to someone who will install Linux or try and recover Windows 7 for you.
We can not help you unless you answer the questions. Every make and model of acer netbooks are slightly different.I have found some boot recovery that you put on a Ian but it can't find it![]()
I dont know what to do?
I have tried to install the mint 11 and thought it was on my usb but was on Android hard drive I think not sure
What is your android hard drive?
Explain please?
Do something for me.
Shut down the pc, remove the battery, usb, sd, and everything that can be removed, with out a screw driver.
Replace battery, then start computer. When you see writing on the screen. Press f12. You may have to hit f12 a few times. Then hit down arrow (to stop the countdown to reboot), write down everything on the screen and report back.
Can you get into your BIOS settings? If Acer's bootloader is interfering, you may be able to find a work around with the BIOS.
Also, when installing a linux distro (which you now don't want to do, but might later..?), you can often tell it where to place the bootloader (likely grub).
So when you boot the pc, you keep hitting f12 and nothing happens?Done this its the same
There is no where to put a cd
It has two window 7 250gb hard drive and 4gb on android but now i cant see any
F12 just shows which order it boots
