Root Need help booting back into recovery...
c0080900v
Nuked my CM 12.1 out of my phone and I accidentally rebooted out of TWRP into system a dummy...
Any ideas how I can reboot my MS323 back into recovery so I can re-flash CM 12.1..?
I did: Full wipe, factory reset, wiped: system, cache, dalvik cache
Am I screwed here...? Or, is there still at least some way..? My MS323 obv only boots to LG logo and gets stuck there now..
Please help...
Please help...
Ok. Try this:
With phone power off, hold at the same time POWER and VOLUME DOWN.
When the Lg logo appears, quickly release the buttons for a quick second and immediately hold the same buttons again.
You will get a message like this: "Do You want to factory reset?"
Select yes
It will ask You again.
Select yes again.
You should be in recovery now.
It may work.
Ok. Try this:
Select yes
Select yes again.
It may work.
Sweet, worked. Thanks. It was right under my nose.
