Root Need help! Bricked. Phone only boots into cwm
Hdjc28
Member
I took my sd card out for a second and nowmy phone wont complety boot up. Its stuck in cwm and im getting bad boot message "recovery" message. I have tried to flash stock rom and it flashes but still wont boot. I get lg screen and it immediately goes into cwm again. Ive flashed boot.img, ive tried everything i know how to do. I know there are other people with this problem and nobody is helping. If anyone knows what to do pls answer. Ive tried the forum with knz and flash the firmware but EVERY link ive tried for the firmware i get access denied from this server.
Did you take your sdcard out WHEN it was flashing? You'll probably need the LG Recovery Tool or something to fix this. It's called bootlooping into cwm when you see the LG logo but then the cwm screen - search for "bootloop into cwm <device name>" with your actual device name replacing the <>, and follow the instructions.
I was not flashing anything. I justvtook it out when phone ws on. It wasnt partitioned either. Idk what happenend. Ive tried the lg support tool and it says my device is not charged and wont continue with update. And its fully charged. I tried wiping battery stats. Idk what else to do. Thanks for your help tho. Seems there is no more development for this phone. But i would really like it fixed. Just put min on it lol
