Need help changing the clock/timer nofication sound
jtborg
Hello there,
I need to change the notification sound on the Samsung Galaxy S default clock / timer.
I can add custom notification ring tone on the alarm ,but not the timer or stopwatch.
I can't find it on the setting or the clock setting.
I just default to a notification tone.
Thank you
James Tom
Hello there,
Go to My Files - Media - Audio - create folder 'alarms' - copy your audio file there and when you set the alarm you will have the custom song in the ringtones list.
Cheers
Anna
