Help need help configuring advanced WEP connection.
kkkkk
Hello,
i can't find a way to configure my phone to my Uni's network, can anyone help?
these are the instructions for windows based computers :
2. Click right click, Wireless Network Connections And select Properties
3. Click the Wireless Network tab Follow the following items: (Fig. 1)
A. Mark at V The option: Use Windows to configure my wireless network setting On. Click the Add button.
At the prompt (Figure 2) must do the following items:
A. In the name (SSID) Network Set Name Dialer WL_BGU
On. In Network Authentication Select the option Open
III. Data encryption field Select WEP
Wed. Mark V Option: The key is provided for me automatically
4. Select Authentication tab Follow the following sections (Fig. 3):
A. Mark V field: Enable IEEE 802.1x authentication for this network
On. Select the option Protected EAP (PEPA) Field: EAP type
Click the Properties button Follow the following sections (Fig. 4):
A. You must remove the mark V field: Validate server certificate
On. You must remove the mark V field: Enable Fast Reconnect
5.Click the configure button
Remove the V from the possibility to
Automatically use my Windows logon name and password
(And domain if any)
6. Click OK Confirmation window
7. Click OK Approval of the previous window
8.After setting window will identify Dialer
Has set the identification information (see Figure 6);
User name : University username (eg email)
Password : Password as e-mail
Logon Domain : BGU-USERS
Thank you
