Help Need help connecting to Win XP PC
iambramha
I am a fresher here so hope this isnt a repost. Got the ACE a cpl of days back and since then have been struggling to get it communicating with a PC. Here is what I have
Win XP SP3 + Kies 2.XX (Latest update as of 28th June)
A fresh ACE, no additional app or updates installed.
These are my observations with USB connection:
1. When I connect the ACE to the PC it always connects in the debugging more.
2. If i turn off the debugging mode, then it connects in the mass storage more.
3. If I turn on the mass storage more -nothing further happens, and Kies tells me, this is not the right mode and connect in the PC studio/Kies mode - Problem is I dont see anything of that sort on my phone!! I have tried all the manuals and docs available.
My observations with Bluetooth:
1. I am able to pair the phone with my laptop and even do file transfers.
2. But Kies says - the device didn't allow a connection?
Its been two frustrating days and am not even able to sync my contacts with the phone...so its practically useless. Any help in this regard would be great.
Auto run not on. Reconnect with phone and go to start menu. Click on computer @ rt column then double clk on drive you are in or rt clk choose open. If you are familiar w/ win, you can handle from there.
