Root need help decompiling settings.apk
fcortes626
i am trying to decompile settings.apk with apk manager but it wont work. this is what i get in the log. am i supposed to decompile with dependencies?
PHP:
|Fri 06/08/2012 -- 14:54:47.58|
java version "1.6.0_31"
Java(TM) SE Runtime Environment (build 1.6.0_31-b05)
Java HotSpot(TM) Client VM (build 20.6-b01, mixed mode, sharing)
Could Not Find C:\Users\owner\Desktop\apkmanager5.0.2\place-apk-here-for-modding\../place-apk-here-for-modding/signedSettings.apk
Could Not Find C:\Users\owner\Desktop\apkmanager5.0.2\place-apk-here-for-modding\../place-apk-here-for-modding/unsignedSettings.apk
I: Baksmaling...
I: Loading resource table...
W: Skipping "android" package group
I: Loaded.
I: Loading resource table from file: C:\Users\owner\apktool\framework\1.apk
W: Config flags size > 32. Exceeding bytes: -2FFE0000.
W: Invalid config flags detected: dimen-v13-ERR0
W: Config flags size > 32. Exceeding bytes: 0000D002.
W: Invalid config flags detected: dimen-v13-ERR1
W: Config flags size > 32. Exceeding bytes: 00040000.
W: Invalid config flags detected: dimen-v13-ERR2
W: Config flags size > 32. Exceeding bytes: 00050000.
W: Invalid config flags detected: dimen-v13-ERR3
W: Config flags size > 32. Exceeding bytes: 58020000.
W: Invalid config flags detected: layout-v13-ERR4
W: Config flags size > 32. Exceeding bytes: 68010000.
W: Invalid config flags detected: integer-v13-ERR5
W: Config flags size > 32. Exceeding bytes: -BFF0000.
W: Invalid config flags detected: integer-v13-ERR6
W: Invalid config flags detected: integer-v13-ERR7
W: Invalid config flags detected: integer-v13-ERR8
W: Invalid config flags detected: integer-v13-ERR9
W: Config flags size > 32. Exceeding bytes: -1FFF0000.
W: Invalid config flags detected: bool-v13-ERR10
I: Loaded.
I: Decoding file-resources...
I: Decoding values*/* XMLs...
Exception in thread "main" java.lang.StringIndexOutOfBoundsException: String index out of range: 17
	at java.lang.String.charAt(Unknown Source)
	at brut.androlib.res.xml.ResXmlEncoders.findNonPositionalSubstitutions(ResXmlEncoders.java:165)
	at brut.androlib.res.xml.ResXmlEncoders.enumerateNonPositionalSubstitutions(ResXmlEncoders.java:142)
	at brut.androlib.res.data.value.ResStringValue.encodeAsResXmlValue(ResStringValue.java:45)
	at brut.androlib.res.data.value.ResArrayValue.serializeToResValuesXml(ResArrayValue.java:55)
	at brut.androlib.res.AndrolibResources.generateValuesFile(AndrolibResources.java:264)
	at brut.androlib.res.AndrolibResources.decode(AndrolibResources.java:137)
	at brut.androlib.Androlib.decodeResourcesFull(Androlib.java:93)
	at brut.androlib.ApkDecoder.decode(ApkDecoder.java:98)
	at brut.apktool.Main.cmdDecode(Main.java:120)
	at brut.apktool.Main.main(Main.java:57)
