Need Help FAST last day to turn in phone
jahada510
i finally decided to keep the epic4gtouch and yesterday this white triangle show up on my screen and stays there. so today is my last day to turn it in. if i get another epic will the same thing happen. are they durable enough to last? i was planning on keeping the phone until sprint got LTE. will photon be more durable? thanks here is a pic of what im talking about
you should ask this .. in the Epic Touch sub-forum.. they would know if this is a normal issue.. or just some odd ball.
My guess, it is not a big deal or a common issue.... if you like the GS2 then get another one.
E4GT is a perfectly capable phone. A good one at that. You should go get yourself a replacement or return it and wait for the next best LTE device on Sprint.
Photon should be more durable and better signal but some downsides are the weight of it, the screen quality, bulkier, slower processor but still dual core and all. Probably the 3rd or 4th best Sprint phone.
Yea get an exchange or hard reset. Keep the Epic Touch if you can.
