need help fast!
so i have had my droid incredible 2 for over a month now and when i got home last night it wouldnt charge, i have tried many different chargers but idk if you can take the battery out or not.
PLEASE HELP!!:confused:
Hello and welcome to Android Forums. Yes you can remove the battery. I would make certain the device is powered off first however. I can't advise you on your charge problem. It is most likely the charger, charger port, or cable but I'm only guessing. We do have a sub forum here for your Dinc2 that you might want to check into to see if users of your device might have some suggestions. Here is a link:
HTC Droid Incredible 2 - Android Forums I hope you can solve your problem.
If nothing else, I'd consider a return.
Welcome to the Android Forums!
You most definitely can remove the battery. Look here and click on the tab that says manuals download.
Once you reseat the battery, plug it in using the charger. If it doesn't charge, then try plugging in a USB cable. If neither of those show charge, then you either have a bad battery or the connector is faulty. Take it to the store and see if a different battery will charge in your phone. If not, then they'll have to replace it.
