need help finding a budget app please
rubinscube
first, thanks for looking at my question:)
I am having difficulty finding a simple budget app that meets my unique income schedule, which is strange because there are thousands.
problem: I get paid the 4th Wednesday of each month.
most apps I have found only allow a specific date not a pattern.
these are the only things I need for a budget:
1. daily amount available to spend based on x amount of days left till payday
2. as mentioned above, a pattern income based on the x Wednesday of each month, not a specific date because some months have less days than others.
I will send positive karma points to any sugestions
If you don't mind linking your banking account(s) to a budget-style app, I've been quite pleased with BillGuard lately. You wouldn't need a particular schedule as it can pull payday information straight from your account. :thumbup:
thanks for the suggestion, I have perused this idea over a Colorado beer, it would require a 1 month buffer to establish a safety net; I will however give it a try. I am sending you good luck karma for that thing that is causing you to worry.
