Need Help Flahing Recovery
I know I have not tried everything but I have tried a lot. I have tried:
-ROM Manger (I flash it and all just does not work)
-Other apps that say they flash recovery files but no luck
if you have any idea please notify me. with downloads and everything needed. or if you know how to fix the original recovery also let me know. when I go into recovery mode at the moment it just has the "Dead Android" in other words the android laying down with the red "!". any kind of help is appreciated :) thanks
Are you running Ice Cream Sandwich (Version 4.0.4)?
If so, the reason is that the bootloader is locked.
On ICS, the bootloader is locked so you can't use a recovery.
You would need to downgrade to Gingerbread, and then root it.
Afterwards, install CWM via ROM Manager and it'll work.
There is no bootloader unlock, for the Lucid.
Can someone here provide a link to the stock recobery for this phone? I flashed the wrong one and now i need to gactory reset to fix a little memory issue and i have no damn recovery.(or i got cwm but it wont boot or whatever it is!) I LIKE this phone. Ima stioooooopidddd for not reading about the locked bootloader but in my defense it was only my haste to remove ugly bloatware that drove me. And thats a just cause, right?
