need help for android documentaiton
jiffclare
hi all :):)
i need help where i can find documentaion for android native application such native ipsec client, if i have issue with it who can i contact, i want to konw where is configuraiton files for it, and more where should i go
Welcome to the forums!
Look under your main settings, Wifi or Network settings depending on your setup and from there to VPN.
Your ipsec VPN credentials will depend on where you're getting the service from.
