Help Need HELP for downgrade galaxy s
styler
Hi,
Anyone can help as mention. I need to downgrade to 2.2 or any Malaysia Firmware version. Due to I want to use KIES to update better than use ODIN.
I have been download DXJPE firmware and install it but cant work properly. It hang on the GALAXY S screen.
Please advice...
From
James
styler.jms@gmail.com
For downgrading, you need to use Odin.
Just download any suitable Froyo version from Samfirmware and use Odin to flash your phone.
its getting stuck in that screen coz i think the bootloaders are missing... just extract the downloaded file and check whether boot.bin and sbl.bin are present in the pda file... since gingerbread and froyo uses different bootloaders...
or else u can download any froyo firmware which has bootloaders (boot.bin) and then u can flash any froyo firmware even which doesnt ve those two files...
Thanks... I already checked. YES. It Miss some found. I take compare with other version DDJV9. It was miss "boot.bin", "dbdata.rfs", "sbl.bin"
So, where can i found complete file? I just search on google and download. After download only know such file is MISS...
Could you please advice, where can download complete file??
Anyway, thanks....
Actually, why i want downgrade my galaxy S due to want keep my phone warranty.
Last time I dunno such issue. Then my frenz ask my upgrade with odin way.
I know those issue when i buy NEW galaxy S2.
Anyone can help?
Thanks...
Re-download JPE from this site,it will come with
the right .pit and etc.
p.s..hit that thanks button if im helping:)
Bro... i already download the file then extract it. but i cant found the file of "boot.bin", "dbdata.rfs", "sbl.bin"
Because without this file, i cant boot on my phone. (info from some helper). it will hang on galaxy s screen only.
So, it is possible i use others Country same version then i put in the file?
so, do you have the guide for me to to do installation, such as the step?
I cant found the wat " mobile code page"
Thanks.
bro... i need some guide. I really confuse for it.
I wan use ODIN for flash my downgrade to froyo.(for warranty purpose)Malaysia
I already download the file from SAMMOBILE but it now complete.
When i extract cant found boot.bin, and 3 more file.
Could you please help for this?
Much Appreciate it....
