Need help from someone with Gal. S2
I entered a new pin for my galaxy 2 and didn't actually memorize the numbers, lol, I did it based on muscle memory. But the number pad when you are setting up the pin is different from the one the one you use after its set up.
So if someone with a galaxy s2 would like to be helpful, i need you to:
1)Go to security settings
2)Tap on the PIN option
3)and upload a picture of what it looks like when it asks you to "enter your pin"
I know I'm an idiot, but I don't want to have to reset my phone or something.
Be a good person and help someone out, then santa clause will give you presents....
...I'm definitely not drunk right now either
It installed an update on it recently so im guessing its the newest one. It wasn't just numbers, it had dollar signs and euro signs, and other stuff. I only used numbers though
I think you used the active keyboard's number view. What keyboard app are you using? You can get there usually by long pressing the numbers key. Its going to be different depending on what keyboard app you are using.
If it came over the air it was probably still a Gingerbread update. The Android v4.0.3 Ice Cream Sandwich and v4.1.2 JellyBean OS updates were downloadable over Kies only if you were on t-moble. I think you're using an international version of the S2 especially if you had all those symbols showing on your S2 PIN setup keyboard. IIRC the symbols options were greyed out on the t-mobile version.
