Need help importing contacts from iPhone to Galaxy S2 phone using Kies...
Ok, I've tried everything and still blanking...
I am trying to add my contacts from my iPhone 4.
It seems simple enough. I connect my S2 phone and Kies shows it as a connected device (SGH-T989). I go to tools, go to transfer data from a non-Samsung device, I click on my S2 phone (as shown on Kies), a new screen opens showing the info on my iPhone, I click contacts, then click agree, then click start, it loads and then shows a red x over my contacts info and also zero bytes in size of data to be transferred - which leaves me with nothing and I close the window.
I can go to connected devices (my S2), go to contacts, and import my contacts (that are saved on my desktop as .vcf format files), and import one contact at a time - which is really a slow way to do it. Isn't there a way to select "all" and import all the files at once?
I've also tried going to "file" in the Kies toolbar and adding both the files and the folder, but I get a notice saying "the file(s) have a format that cannot be played on SGH-T989 (which I assume is my phone).
Any ideas how to transfer the contacts would be greatly appreciated!
Thanks...
Thanks...
