Need help in app
reshmavt
Hi,
I am new to android apps development. I tried to submit my app in amazon but facing some issues. Will really appreciate if somebody helps me to some this issue.
Thanks
The error log from amazon team,
08-11 10:41:29.136 W/dalvikvm(3898): VFY: rejecting call to Lcom/amazon/android/Kiwi;.onActivityResult (Landroid/app/Activity;IILandroid/content/Intent;)Z
08-11 10:41:29.136 W/dalvikvm(3898): VFY: rejecting opcode 0x71 at 0x0000
08-11 10:41:29.136 W/dalvikvm(3898): VFY: rejected Lcom/android/mygroceries/DataBaseHelper;.onActivityResult (IILandroid/content/Intent;)V
08-11 10:41:29.136 W/dalvikvm(3898): Verifier rejected class Lcom/android/mygroceries/DataBaseHelper;
08-11 10:41:29.136 D/AndroidRuntime(3898): Shutting down VM
08-11 10:41:29.136 W/dalvikvm(3898): threadid=1: thread exiting with uncaught exception (group=0x400259f8)
08-11 10:41:29.136 E/AndroidRuntime(3898): FATAL EXCEPTION: main
08-11 10:41:29.136 E/AndroidRuntime(3898): java.lang.VerifyError: com.android.mygroceries.DataBaseHelper
08-11 10:41:29.136 E/AndroidRuntime(3898): at com.android.mygroceries.mainmenu.onCreatemainmenu(mainmenu.java)
08-11 10:41:29.136 E/AndroidRuntime(3898): at com.android.mygroceries.mainmenu.onCreate(mainmenu.java)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1069)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2751)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2803)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.app.ActivityThread.access$2300(ActivityThread.java:135)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2136)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.os.Handler.dispatchMessage(Handler.java:99)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.os.Looper.loop(Looper.java:144)
08-11 10:41:29.136 E/AndroidRuntime(3898): at android.app.ActivityThread.main(ActivityThread.java:4937)
08-11 10:41:29.136 E/AndroidRuntime(3898): at java.lang.reflect.Method.invokeNative(Native Method)
08-11 10:41:29.136 E/AndroidRuntime(3898): at java.lang.reflect.Method.invoke(Method.java:521)
08-11 10:41:29.136 E/AndroidRuntime(3898): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:868)
08-11 10:41:29.136 E/AndroidRuntime(3898): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:626)
08-11 10:41:29.136 E/AndroidRuntime(3898): at dalvik.system.NativeStart.main(Native Method)
08-11 10:41:29.146 W/ActivityManager(97): Force finishing activity com.android.mygroceries/.mainmenu
my database activity file:
public class DataBaseHelper extends SQLiteOpenHelper {
private static String DB_PATH = "/data/data/com.android.mydatabase/databases/";
private static String DB_NAME = "knowLanguage.db";
private SQLiteDatabase db;
private final Context myContext;
* Constructor
* Takes and keeps a reference of the passed context in order to access to the application assets and resources.
* @param context
public DataBaseHelper(Context context) {
super(context, DB_NAME, null, 1);
this.myContext = context;
public void createDataBase() throws IOException{
try {
if(!this.checkDataBase()){
try {
this.getWritableDatabase();
/*Log.i("DATABASE:", "WRITABLE");*/
} catch(SQLiteException ex) {
this.getReadableDatabase();
/*Log.i("DATABASE:", "READABLE");*/
this.close();
try {
this.copyDataBase(myContext);
/*Log.i("DATABASE:", "COPY");*/
} catch (IOException e) {
Log.e("Database Error:", "Error copying database");
this.close();
} catch(SQLException eSQL){
Log.e("log_tag","Can not open database");
private boolean checkDataBase(){
File dbFile = new File(DB_PATH+DB_NAME);
return dbFile.exists();
public SQLiteDatabase copyDataBase(Context context) throws IOException,SQLiteException{
if (db != null && db.isOpen()) {
db.close();
File fileTest = context.getFileStreamPath(DB_NAME);
boolean exists = fileTest.exists();
if(exists==false)
InputStream myInput = context.getAssets().open(DB_NAME, Context.MODE_PRIVATE);
OutputStream myOutput = new FileOutputStream(DB_PATH + DB_NAME);
byte[] buffer = new byte[1024];
int length;
while ((length = myInput.read(buffer)) > 0) {
myOutput.write(buffer, 0, length);
myOutput.flush();
myOutput.close();
myInput.close();
return db = SQLiteDatabase.openDatabase(DB_PATH + DB_NAME, null, SQLiteDatabase.NO_LOCALIZED_COLLATORS);
public void openDataBase() throws SQLException{
String myPath = DB_PATH + DB_NAME;
db = SQLiteDatabase.openDatabase(myPath, null, SQLiteDatabase.OPEN_READONLY);
@Override
public synchronized void close() {
if(db != null && db.isOpen())
db.close();
super.close();
@Override
public void onCreate(SQLiteDatabase db) {
@Override
public void onUpgrade(SQLiteDatabase db, int oldVersion, int newVersion) {
