Need help, Infinite Boot Loop (have logs)
My EVE seems to does this every couple days and then I have to wipe everything of the phone using "Fastboot -w". But I'd like to figure out why this is happening so I'm starting to log stuff using logcat through adb.
Here is what I think may be the issue but you tell me. I'm totally new to trying to debug this thing.
This is a series of Errors that occur when the android loop screen locks up and restarts the boot loop.
E/AndroidRuntime( 6118): java.lang.IllegalStateException: Cannot broadcast before boot completed
E/AndroidRuntime( 6118): at com.android.server.am.ActivityManagerService.broad castIntent(ActivityManagerService.java:10389)
E/AndroidRuntime( 6118): at android.app.ApplicationContext.sendStickyBroadcast (ApplicationContext.java:930)
E/AndroidRuntime( 6118): at com.android.server.ConnectivityService.sendConnect edBroadcast(ConnectivityService.java:483)
E/AndroidRuntime( 6118): at com.android.server.ConnectivityService.handleConne ct(ConnectivityService.java:568)
E/AndroidRuntime( 6118): at com.android.server.ConnectivityService.access$500( ConnectivityService.java:48)
E/AndroidRuntime( 6118): at com.android.server.ConnectivityService$MyHandler.h andleMessage(ConnectivityService.java:714)
E/AndroidRuntime( 6118): at android.os.Handler.dispatchMessage(Handler.java:99 )
E/AndroidRuntime( 6118): at android.os.Looper.loop(Looper.java:123)
E/AndroidRuntime( 6118): at com.android.server.ConnectivityService$Connectivit yThread.run(ConnectivityService.java:91)
E/AndroidRuntime( 6118): Crash logging skipped, no checkin service
E/installd( 1067): eof
E/installd( 1067): failed to read size
E/appproc ( 6155): Can't open data/nv/command
BEST TECH IN 2023
Smartphones
