# cat /sdcard/flash_image> /system/bin/flash_image
button combination is most likely power+volume up+home(long press at the same time)Yay!! Yes!I just did it!!!I'm very happy
Hey, do you know the button combination for booting into recovery?And yes, do I need to factory reset(wipe data) my phone via CWM?Thanks!
Do you have a custom recovery already installed? If so it's actually pretty easy to change the recovery. Rename the recovery to recovery.img (this will make it easy to get the name right when you type in the code). If you already have a recovery on the SD card with that name, rename it to whatever the first letter is in the name, then recovery.img. Example: I renamed the Xionia recovery to xrecovery.img. I have several recovery's on the sd card but by renaming them in this manner I can easily flash anyone one I want without having to look on the sd card first or change names around.
Next open up the terminal emulator that you downloaded from the PlayStore.
Type in: su (then hit the enter key)
You will get a Superuser prompt, select accept/allow. Go to the menu and select toggle soft key board.
Now type in: flash_image recovery /sdcard/recovery.img (or whatever you renamed the recovery to),(hit the enter key).
That's it.
You might get a stream of almost identical looking code after hitting the enter key, this is normal. As long as you got no error message's in the code and you got a # at the end, then you can type in this:
reboot recovery (hit the enter key).
This will take you to your new recovery's menu screen.
If this is going to be your first custom recovery, let me know. I'll get you hooked right up. Installing it from a terminal emulator of by using the Flash Image GUI is pretty simple and does not require the use of a PC.
Make sure flash_image is in sdcard/ Also one of the commands gives file not found but not sure if this is the one.
