Groovey252
Okay, So I rooted my phone last month using Razr Bootstrap, I just used Titanium Backup Pro for my Apps. I tried to update to ICS but I received a message saying install failed. I assume it is b/c I rooted.
Now my question is, if I flash back to stock, then do the system update, can I just re-root my phone the same way I did before, do a factory reset and install Titanium backup Pro to restore all my apps? Will my apps just appear again? Do I need to remove my SD card? Kind of confused on how I will get my apps back...
