Help Need Help - Motorola 4 (Slider)
To be perfectly honest I am not he most technical person out there but I have been having trouble with my phone for a while and I am starting to think that its because I have too many apps that are using RAM. I recently started using clean master (although I suspect it uses more RAM than it should) and it seems to help but I am routinely 85% RAM usage. I always clear apps that I am not using, rarely have more than one open and yet my phone is constantly freezing. I just recently realized that Avast Security was using 100 MB of RAM and disabled it but I am not comfortable not having it working and overall my phone is routinely using 750 MB (including Avast).
Should I stop apps from automatically updating? Should I stop using certain messenger apps? Also I'm not sure my phone ever upgraded Jelly Bean.
Thanks in advance.
Ray
Lose Clean Master, it's lying to you.
http://androidforums.com/threads/pu...k-killers-ram-optimizers-and-the-like.896663/
For the most part, your apps will go into hibernation - using no power.
Your phone will use the same power on ram whether it's 10% empty or 60% empty.
Android knows how to handle the rest.
The thread will cover any questions you have.
It sounds like you have a rogue app - either a bad install or just crappy code.
GSam Battery Monitor can help you track it down.
I got rid of clean master and installed Gsam battery monitor. It lists Kernel as the operating system. Can I get jelly bean on my device?
I got rid of clean master, downloaded Gsam battery monitor and noticed that Kern is listed as my OS. Can I get jelly bean on my device?
