Need help! Phone keeps shutting off!
I have a rooted Nexus 4 and every now and then, the phone keeps shutting itself off and it won't turn on again until after a few attempts or by going into bootloader mode. Anyone else have this problem and know how to fix it? Thanks in advance.
Hello, ShadowKnight, welcome to Android Forums! :)
Are you running a custom ROM/stock ROM? How long have you been experiencing issues? Is it always after using a certain app that your phone turns itself off?
Thanks for the warm welcome. :)
It's a stock ROM, I've been experiencing the issue for the last 3 days, it doesn't happen while I'm using any app. It just simply turns itself off sometimes while the phone is not in use.
Do you see the phone shut down? Or is it just off when you pick it up?
Two things come to mind if it just goes off without a proper shutdown. Either it's a failing battery or some sort of thermal protection circuit that kills the power.
Just thinking out load.
It's just off when I pick it up.
How would I be able to determine which of those two problems it might be?
Has the phone ever shut off in the middle of using it? Or does it always happen only when idle?
(I don't see a "game killer" app in the play store.)
It has shut off twice before when using that app but now it only happens when the phone is idle.
(As Lion said, it's an app that hacks games.)
Had it shut off like that before you installed the app?
Nope. So I guess that's the problem? Well I'll uninstall the app and see how things go over the next few days. If the problem still persists, I'll tap back to ask for more help. If not, thanks for your help! :)
