Root NEED HELP!! Phone won't start.
Gilbster
So I was looking online and I tried to find a way to force the camera on my phone to not make a noise. Basically I edited one line in my build.prop, and restarted my phone. But now my phone won't load!!!! It's shows the white samsung logo and then goes blank. I can get it into recovery just not sure what to do from there. My mac doesn't recognize it either. Any help would be appreciated.
Do I have to do a 'wipe data/factory reset'?
I think If i could get a stock build.prop I could push it to my phone using adb shell. But need help!!
here is a build prop, not entirely stock, but it should work i think
Did it work for you?
i chanaged my build.prop density from the default 240 to 242 or 243 and my reverb goes to the samsung sighn and then to a blank screen. how do i fix. im guessing i have to replace modded build.prop with the stock/default unmodded build.prop but how do i do that ?? please help me..
two ways...
if adb recognizes the phone... use that to push the file..
if not, you can create a flashable zip to push the file instead
edit: third and easiest way... you can flash the aroma file manager...
and use that to move the file from sd to phone...
1. download this file on your pc
2. extract the 'sdk' folder to a directory of your choice.. for me it will be 'C:/'
3. open the sdk folder and place the stock 'build.prop' in there (make sure it is named build.prop and not anything else...
4. now open up command prompt and plug in your device
5. power on your device... if it bootloops, allow it to do so...
6. type in
HTML:
cd C:/sdk
7. next type in
HTML:
adb devices
8. if your device shows up continue to the next step... if not, this method will not work
9. type in
HTML:
adb push build.prop /system
10. once completed, type
HTML:
adb reboot
11. your device will reboot and should work again... :)
i will try this im sure it will reconize my device because odin reconized it (needed odin to download clockwordmod) and i installed samsung drivers so yea i will try but the only thing that get me is that when ectracting the folder it take 30 mins (tried installling sdk before but quit because of the 30 mins worth of extracting)
this isn't the sdk and shouldn't take 30 min... its only the files necessary for adb...
when i click on adb exe after extracting the terminal pops up and then starts loading then after that it clicks off and another tip my phone isnt on the debug like when you go in and check is and im not on a administrator profile .
follow the instruction i wrote... never do they tell you to double click adb.exe
edit: actually... you can try to flash this... might not work but wont do any harm... flash it like you would flash any file in recovery...
how do i flash it .. and when i put in the commands it says that they cant be reconize it because im using a regular account instead of an administrator account?
heres how to flash...
1. put the file on your sdcard
2. get into recovery
3. scroll down (using volume buttons) to 'install zip from sdcard'
4. press the power button
5. scroll to 'choose zip from sdcard'
6. press the power button
7. scroll down to the file
8. press the power button
9. scroll to 'yes - install'
10. power button
11. the file should flash...
12. once its done, reboot and everything should work again...
as for the adb issue... you should use the administrator account from your computer
ohh ok but how do i get the file to my sd card i know how to flash now but how do i get it to my sd card and also my brother has the same phone galaxy reverb should i use his phone to put the file on my sd card then transfer it to my phone?
you can do that...
ok i need to unpack my phone from the box we were about to send to samsung i dought if they were going to figure what happend to it anyway.
My brother wont let me use his phone to put file on sd card is there another way to put it on my sd card by any chance because i have a feeling its going to work
