need help, please
davisjs
Hi...trying to find our how to move my contacts from palm tungsten e2 to my droidx. can anybody help or tell me where to go for help?
Welcome to the Android Forums!
If you use the Palm Desktop application, check to see if you can export your contacts (preferably in comma delimited or VCard formats). If you can then you can take the output and import it into Gmail through it's web interface.
With a comma delimited file you might need to define what fields are in the file and what order the fields are in...
