Need help plz
Hey need help my droid 2 been working good tell it turned off on its own. Now it wont load its stuck on the bootloader d2.37 battery low cannot program. What do i do
Its not the wires it was working fine like a week ago and iy died on me. When i got home i plugged it n an it started charging. I took it off the when it was charged it worked fine n tell i played a game it froze an shutdown an when i yrid to turn it back on thays what it gave me that error.
bootloader says low battery
that means you can not flash sbf until a charged battery is in phone
maybe battery has failed
edit: generally when phone is stuck in bootloader, fix is to flash sbf recovery image
but you could try wiping cache or data in android recovery
try reading
the 2nd link in 2nd post or try
http://droid.koumakan.jp/wiki/Welcome
but your main problem is low battery
pull battery, replace, connect to wall charger, does charging mode start, or bootloader
if it charges great, let it charge completely
if no charge, find a charged battery
then post back here
if phone boots straight to bootloader, from power off then connected to wall charger
wiping data is likely not going to help
not that i know of, and if you haven't charged battery,
if phone died in the middle of update it may really be bricked
Yeah its till on the d2.37 dont really wanna do the update. But did try the brass contacts an wired them but it gave me the same thing except it said battery ok program ok
